Workflow APP 1.5 + Illustrator Cs2...
COW Forums : Adobe Illustrator
Uwe
by
on Dec 29, 2005 at 11:32:52 am
can anybody explain an effective workflow between APP + Illustrator CS 2. I want to change the frames of a short clip into vector graphics with Live-Tracing (palettes etc.) and then reimport to APP. Obviously Illustrator can
Troy E. Parker
Re: Workflow APP 1.5 + Illustrator Cs2...
on Dec 29, 2005 at 2:54:02 pm
Hi Uwe,
Don't use APP here ( we use Final Cut Pro), but you should be able to export your clip as a numbered image sequence, import into Illustrator to do the vector conversion, and then import back into APP maintaining the number sequence in the file names. From here you will need to add to a sequence timeline & render out in the desired format & Codec for use in your main timeline.
regards,
T
troy@crossmediacorp.com
http://www.crossmediacorp.com
Uwe
by
on Dec 29, 2005 at 4:45:17 pm
Thank you. Is there any possibility to change (f.e. Live-Tacing...) a lot of stills (50 frames...) all at once, or only by edit every single frame...?
regards
Uwe
Troy E. Parker
on Dec 29, 2005 at 6:32:53 pm
Hi Uwe,
Adobe Bridge will allow you to batch process images with Live Trace (10 file limit per action), and has a pre-programmed script to get you started
You will need to create a Live trace preset in Illustrator that gives you the look you want prior to the batch process.
This following link is a PDF from adobe that should get you started.
http://www.adobe.com/products/illustrator/pdfs/creating_vector_content.pdf
Regards,
Troy
Uwe
by
on Dec 29, 2005 at 6:48:56 pm
Thank you very much Troy. This helps a lot. Have a nice day...
kind regards
Uwe
