Effects and Filters are greyd-out in Illustrator
COW Forums : Adobe Illustrator
David Cohen
on Dec 6, 2005 at 8:09:20 pm
This is a simple but frustrating one. For some reason alot of my effects and filters are not available in the drop down lists. Not sure why, is it a color seting, or doc setup? Any help would be appreciated.
Cheers
-Dave-
seth
Re: Effects and Filters are greyd-out in Illustrator
by
on Dec 7, 2005 at 4:43:54 pm
Most likely it is because your document is set to CMYK. If you set your color mode to RGB, they should all be available.
utah dvd replication - stotion.com
