Temporarily turn off effect? - Illustrator
COW Forums : Adobe Illustrator
Naveen Mallikarjuna
on Nov 11, 2005 at 3:12:33 pm
Is there a way to turn temporarily turn off an effect in Adobe Illustrator CS2?
I have a 3D effect on some text. However, I would like to be able to edit the text and change it's color, without having to wait for the memory-intensive 3D effect to render every time I do this.
I could not find anything in the Appearance palette. Is it possible to just disable this effect, and then turn it back on once I've settled on the color/words?
Naveen
Mike Gondek
Re: Temporarily turn off effect? - Illustrator
on Nov 17, 2005 at 8:30:51 pm
Would be great if appearance had visibility icons and the ability to change stroke weight there.
There is no way to temporarily turn off the effect. The only adice I can offer is to in the 3D Effect turn off shading(everything shuodl go much faster), then turn it back on when done.
kotias
on Nov 22, 2005 at 4:12:19 am
Try temporarily turn off Make Preview/Outline Ctrl+O and write needed text in outline mode.
