importing AI CS2 into AE
COW Forums : Adobe Illustrator
lriv
by
on Oct 17, 2005 at 4:56:14 pm
I'm trying to import illustrator CS2 outlined text files into after effects, but the text gets cropped based on the document size instead of my bounding box. I've tried the following solutions without success:
- Saved in legacy format, but it still gets cropped
- Turned off "use compression" in CS2, but it gets cropped
- increased the document size (700x5300 pt - due to the project) but I get an invalid error that doesn't go away even after I click OK
- saved as eps format, which works fine except if I need to have multiple layers
Any advice is appreciated...thanks in advance
seth
Re: importing AI CS2 into AE
by
on Oct 18, 2005 at 5:17:58 am
It may be helpful to rasterize the text if you don't need it to be vectorized. Or, can you paste the paths into AE?
utah dvd replication - stotion.com
lriv
by
on Oct 18, 2005 at 4:32:13 pm
Due to the kind of job, I do need the text to remain vectorized. Also, because my AE projects rely on the positioning of my AI files, I need to be able to just import the files rather than copy and paste the paths. Thanks much for your help.
Judy Wium
on Mar 1, 2012 at 8:04:36 pm
Oh I didn't embed it. It is here:
