exporting into final cut pro
COW Forums : Adobe Illustrator
Martin Sterling
on Oct 17, 2005 at 1:57:16 am
I'd like to know how to export an illustrator file with an alpha channel into final cut pro with the alpha intact. It usual comes thru with a with ebackground.
Thank You in advance
Richard Harrington
Re: exporting into final cut pro
on Oct 20, 2005 at 1:01:34 pm
Save as PNG or take into PS and do it there
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
