Long File save time in Illustrator
COW Forums : Adobe Illustrator
Asaf Billet
on Oct 16, 2005 at 11:51:10 am
When I'm saving a file in Illustrator CS (OS X), it takes a lot of
time to save the file. There is an EPS pic in the document.
Is there a way to make saving files quicker ?
It reeeeaaaally hurts my workflow.
cheers
ace
Seth Olson
Re: Long File save time in Illustrator
on Oct 20, 2005 at 1:43:19 am
What is the resolution for the EPS image? Does it take as long to save if you remove the image? Perhaps you could work with a JPEG version during the work flow and replace it once you are done? What are you saving as?
