Illustrator newbie question (artboard)
COW Forums : Adobe Illustrator
on Sep 10, 2005 at 5:09:21 pm
I have artwork that is outside the artboard, how can i move the artboard so that the artwork is inside the artboard or vice versa..
Richard Harrington
Re: Illustrator newbie question (artboard)
on Sep 10, 2005 at 6:08:26 pm
Change your document size under the File menu or drag the artwork in using the selection tool
I answered becuase you asked nicely...
Look on the home page
Media Professionals User Forums - More Signal, Less Noise....
This is not a place for questions that would be solved from readingthe first chapter of the classroom in the book or user manual... if you are going to purchase expensive software, be sure to investigate basic funtionalty through training.
Good Luck
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from
edit - produce - direct -
© 2018 All Rights Reserved
