cliping path
COW Forums : Adobe Illustrator
dreq
cliping path
by
on Jul 29, 2005 at 12:34:42 pm
When i import a picture in illustrator cs and make a cliping path on it the previos picture bounds still remain and can be seen when in outline preview. Is there a way to get rid of them and keep only the clipping path bounds?
I need this because when i make a pdf it makes it including this bounds too, and its generelly annoying.
Thx in advance.
Arie Stavchansky
Re: cliping path
on Jul 29, 2005 at 2:49:54 pm
Not sure if this would work, but you may have to export the Illustrator file as a layered PSD, then copy the bitmap of your image from the Photoshop file back into its proper place in Illustrator. It's a complex work around, and there is probably a simpler way, but it may do the trick.
Hope that helped!
Arie
dreq
Re: cliping path
by
on Jul 29, 2005 at 6:23:45 pm
hmm i guess this would work, but i was wondering if there's a simpler way to do this. Thx anyway
