illustrator font menu missing
COW Forums : Adobe Illustrator
on Jul 13, 2005 at 10:45:18 am
I am no longer able to open the illustrator. everything started when i want to change my account name. When I realized that i have created to many new accounts I'v decided to do same cleaning. As a result i can no longer open the Illustrator. Reinstalling "Ilumina" fix the problem for that software. but doing the same to Illustrator had no result. (iMac G5 Tiger/Illustrator CS)
Have you any ideas ? If needed I can provide few screen shots. Thanks
Mike Gondek
Re: illustrator font menu missing
on Jul 14, 2005 at 7:53:17 pm
try resetting your prefs. Boot phothsop, immediately dpress shift command option and click yes to reset prefs.
Sound though like you are missing some components of photoshop, like no filters menu. In this case you will have to reinstall yet again.
Run disk first aid (fix permisssions) prior to install as you may have folders that are locked, and disk first aid fixes this returning problem to Mac OSX.
© 2018 All Rights Reserved
