AI CS > v.9
COW Forums : Adobe Illustrator
stu denbigh
AI CS > v.9
on Jul 8, 2005 at 4:09:38 pm
HI -
I have created an Illustrator CS document which contains brush strokes only.
Is there any way to open this (preferably with layers) in an older version of Illustraor - I've tried saving as an eps, but it doesn't work.
Any help appreciated.
s
t
u
Arie Stavchansky
Re: AI CS > v.9
on Jul 8, 2005 at 4:24:06 pm
You should expand the brush strokes into basic shapes before saving it for an earlier version. I think it is in the "Object" menu at the top. Once expanded, the brush stroke is not "procedural" so to speak, and that is what makes it incompatible with earlier versions. Saving as an EPS will work fine as long as the objects are expanded.
Arie
