Problem with Illustrator CS2 and Importing in AE. Cropped Files
COW Forums : Adobe Illustrator
Marco
on Jun 29, 2005 at 9:26:46 pm
Ok i have Illustrator CS2 and I have a object that is bigger than the artboard. When I tried importing that file in After effects, it cropped my object where the artboard is in Illustrator. I have the first CS so I know about AICB Preserve appearance and overprints and I even created a box bigger than the artboard and made it as a crop mark but when I bring it in After effects it still cuts my object. Can anyone help me out please.
Marco
bill0199
Re: Problem with Illustrator CS2 and Importing in AE. Cropped Files
on Jul 4, 2005 at 10:22:58 pm
Have you tried saving it in any of the legacy formats? CS, v.10,9 or 8? Try turning the "use compression" switch off when saving in CS2 format. I assume you've created the crop marks around the boundry of your artwork (outside the artboard boundaries). Not sure if that helps or not.
