creating tables in Illustrator
COW Forums : Adobe Illustrator
Chris617
on May 22, 2005 at 6:39:13 pm
Is there a way to create a table for print with Illustrator CS?
Do tables have to be created with the pen tool? I'm having trouble
using the Rectangular Grid tool to do this. . .
Are you aware of a tutorial on how to create tables in Illustrator?
Thanks for your help.
Chris
Thumbslinger
Re: creating tables in Illustrator
on May 23, 2005 at 1:10:28 am
What kind of problem are you having with the rectangular grid tool?
Creating a table by drawing a line and then duping and using the Align palette to Distribute evenly is fairly quick if you need custom sizes, but you can also just use Rules beneath type for all your horizontals which will be automatic, and then add vertical where you want them.
