PAR and After Effects
COW Forums : Adobe Illustrator
Jim Wilcox
on May 11, 2005 at 10:29:33 pm
Since as of Photoshop CS (I think) you can now compose all PSD's at 720x486 non Square pix, is that the preferred method folks use when creating PS elements for import into AE that will be used in D1 720x486 compositions and renders? There is always talk about mixing square and non square and what trade offs image quailty-wise one might suffer. Am I missing something basic here, or should one just work with D1 all the way though if that is your intended output from AE? CS even has a D1 preset for it... what am forgetting here?
Thanks for any thoughts!
Richard Harrington
Re: PAR and After Effects
on May 12, 2005 at 1:56:05 am
Unless mixing in flash or AI
Stay non square all the way through if delivering to a NS format
Jim Wilcox
on May 12, 2005 at 5:10:17 am
Richard,
Thanks for the reply. Perhaps another dumb question, but I assume Illustrator is only outputting Square? In that case working square would be the way to go?
