This Forum is Weak
COW Forums : Adobe Illustrator
Charley
This Forum is Weak
on May 10, 2005 at 5:55:39 pm
This is the worst place for PS info.
Thumbslinger
Re: This Forum is Weak
on May 11, 2005 at 2:20:59 am
I'm assuming you either:
1- got razzed for asking something that may have been considered too 'beginner' by some.
2- didn't use proper grammar and resorted to silly abbreviations which meant nothing to anyone.
3- didn't clearly phrase your question and so therefore, didn't get a response.
4- got upset because someone wouldn't actually 'do' something for you.
5- some other reason? (fill in the blank)
My perception of this forum is that it is part of something bigger. It's an educational repository of both real world and weekend rubber-stampers who share and ask regardless to which category they may fall under. Which is awesome.
Yes, this particular forum says Photoshop/Illustrator, but the Cow is the big picture.
Look in other forums, cross-search your questions here at the Cow.
Otherwise, if all you want is a Photoshop forum, may I suggest Google with "Photoshop" "tight" and "sic" as the parameters.
MathDreamer
on May 11, 2005 at 5:18:58 am
I personally find it very valuable. The people are polite and helpful. I feel that you making a blanket statement without any reasons shows that you are right that this place is not for you.
-Rob
maxrez
on May 12, 2005 at 4:10:16 pm
If you can find a nugget here and a tip there, then this forum is valuable. Otherwise, join NAPP and try somewhere else.
Andrew J. Bricker
on May 15, 2005 at 3:27:28 pm
Go get some lessons!
