Illustrator pattern problem.
COW Forums : Adobe Illustrator
Charles
on May 4, 2005 at 12:21:04 pm
Date: May 3, 2005 at 22:18 gmt
Subject: Illustrator pattern problem.
I have a problem with Illustrator.
I have a element that I want to fill with a pattern that I made myself (made it from my background image).
(see: http://www.trancevibez.com/koozftp/Charles/Screen1.jpg )
But when I define it to my element and I move the element the patters stays at the same position so that it changes every time I move it. Is there a way to define it to my element so that it stays the samen wehen I move it?
(see: http://www.trancevibez.com/koozftp/Charles/Screen2.jpg )
I tried it also with another pattern (standaard from Illustrator) but the it does the same.
I can not work with transparancy because of all the layers behind that need to cover each other.
I hope I explained it clear enought. Any suggestions?
Thnank you for your time.
Grtz. Charles
Kim Mackenzie
Re: Illustrator pattern problem.
on May 4, 2005 at 6:38:34 pm
Transform Palette > flyout menu > change it from Transform Object only to Transform Both. Should do the trick.
Charles
on May 5, 2005 at 9:47:13 am
Yah!!! thank you so much!
Gr. Charles
