vector paths in photoshop
COW Forums : Adobe Illustrator
doug
by
on May 4, 2005 at 2:46:43 am
Is there a way to turn a selection into a vector path.
thanks and
Hail the Cow.
Doug
Jeff Cochran
Re: vector paths in photoshop
on May 4, 2005 at 4:00:39 am
There is,
Make your selection. Under the window pull down menu, bring up the paths palette. Go to the pull down menu to the right of the palette and go to Make Work Path. Select a tolerance value (the smaller the value, the more points on the path) and hit OK. You have a path.
If your going to use this path for print as a clipping path or in Illustrator, I'd suggest a tolerance no smaller than 1.5. Anything smaller will usually give an imagesetter problems.
Jeff Cochran
http://www.jeffcochrandigitalartist.com/
Kim Mackenzie
on May 4, 2005 at 12:57:19 pm
Path Palette > flyout menu > Make Work Path
Lower tolerance = more detail (which you may not want if the selection is jaggy).
Then double click the work path to give it a name and save it.
doug
by
on May 4, 2005 at 10:41:07 pm
Thanks for your help
