Seems to be simple but I can't figure this out.
COW Forums : Adobe Illustrator
Chris S
on Apr 25, 2005 at 6:42:30 pm
http://members.cox.net/fishgrease/ribbon
I need to make ribbons similar to the one in this pic. I will need to make several differently shaped ribbons but with the same sort of looping helix-like pattern. Is there a way in Illustrator or Photoshop to sort of automate this pattern as I draw with the paintbrush or pen tool? thanks
Troy E. Parker
Re: Seems to be simple but I can't figure this out.
on Apr 25, 2005 at 7:00:32 pm
Illustrator would be a good bet here.
It appears that the ribbon could be done with a brush that is one of the light/dark shapes, and just repeat. Pattern applied to a path might work also and allow you reshape path...lay the other graphics above on another layer.
T
Chris S
on Apr 25, 2005 at 7:15:33 pm
Thanks for your response.
I am not familiar with Illustrator much...but my lab does have it on the computer. Will you please xplain how to do what you suggested or direct me to a tutorial that will teach me how to do what you suggested? Thanks again.
