adjust corner radius
COW Forums : Adobe Photoshop
Corey Pike
on Feb 19, 2020 at 4:06:07 am
Greetings, I am trying to round off corners on a rectangle in the latest version of Photoshop CC. Multiple online tutorials assure me that in the Properties Panel there is text boxes for adjust the corners. Lo and behold when I go to the Panel on my Photoshop, there is no such adjustment ability. There is a Transform area that has width, height, x, y, rotate, flip horizontal and flip vertical.
Does anyone know where I might be able to find the boxes for adjusting the corner radius?
Thank you
John Williams
Re: adjust corner radius
on Feb 26, 2020 at 9:56:04 am
Hi there, what sort of rectangle are you talking about? A selection or perhaps a shape?
With a selection you can modify the selection Select/Modify/Smooth
With a shape you can of course make a 'Rounded Rectangle' or if you have made a standard rectangle then in the Properties panel you can alter the Corner radius, either for all corners or individual corners, this still functions as it did in previous versions. Is there any chance you are working in a different workspace or customised layout that you cannot see those options?
Best, John
John Williams
Soho Editors
John Williams
on Feb 26, 2020 at 9:56:51 am
John Williams
Soho Editors
