How to get lines glow like this
COW Forums : Adobe Photoshop
Luis Garcia
on Mar 19, 2019 at 9:27:17 pm
I would like to do lines like this
https://www.shutterstock.com/es/image-illustration/abstract-blue-glowing-ci...
thanks
Kevin Camin
Re: How to get lines glow like this
on Mar 20, 2019 at 3:08:05 am
For the middle glowing rectangle, you can do an inner glow if it's a separate layer or just draw the inner glow. Then you can create the outer flow by duplicating the rectangle and coloring it lighter, blurring it, putting it in a screen or overlay mode and adjusting its opacity.
For the outer lines, you can brighten or darken the lines with an adjustment layer and feather out a mask.
I mocked it up for you. Hopefully you can look at each layer and figure it out.
https://we.tl/t-0Qjg1Kd1IU
Best regards,
Kevin Camin
