save for web in the selected marquee area only
COW Forums : Adobe Photoshop
ben wolfinsohn
on Feb 9, 2019 at 12:03:31 am
Is there a way to save for web or export for jpg only what is currently highlighted with the marquee tool? normally I have to first crop the entire image first. or copy visible area that is highlighted, then open a new document, then paste, then save or export for web. was trying to reduce a few steps.
Kalleheikki Kannisto
Re: save for web in the selected marquee area only
on Feb 10, 2019 at 7:20:31 am
You can create a slice with the slice tool and export for web, selected slice only.
Senior Graphic Designer
ben wolfinsohn
on Feb 10, 2019 at 7:14:49 pm
got it. and is there a easy way to create a slice based on an already existing shape?
thanks!
on Mar 6, 2019 at 5:29:06 pm
Sorry, haven't been here for a while...
If the shape in question is on it's own layer, you can use the "new layer-based slice" function.
