selection and layer mask
COW Forums : Adobe Photoshop
Nathan Kendall
on Dec 31, 2018 at 5:01:10 am
I have a selection and a curves with layer mask.
I want the selection to be the layer mask so when I use curves it only makes adjustment within the models eye.
Kalleheikki Kannisto
Re: selection and layer mask
on Dec 31, 2018 at 12:36:13 pm
You can either
A) delete the layer mask and add a layer mask while the selection is still active or
B) select inverse and fill the outside are of the layer mask with black
Same outcome both ways.
Senior Graphic Designer
