Hexagon mosaic filter ?
COW Forums : Adobe Photoshop
Al Bongo
on Nov 25, 2018 at 6:39:43 pm
I would like to add a mosaic like filter to some art work - the same effect as with the stained glass filter but with Hexagons - ive seen it done and wondered how - i cant find the answer anywhere !
Kalleheikki Kannisto
Re: Hexagon mosaic filter ?
on Nov 26, 2018 at 10:09:15 am
One option:
https://www.filterforge.com/filters/5484.html
Senior Graphic Designer
Pieter Léon Vermeersch
on Jul 3, 2019 at 7:42:55 am
You can make it yourself. Look for a black and white hexagonal pattern in Google Image.
You can add some gradient in the hexagonal shapes by doing a soft selection and filling it with black. (selection > modify > deather).
Then you put it in a seperate layer and use the soft light blending mode for example. In combination with some blur filter.
Tip: first search for a reference photo and try to copy the effect
Here you can see my work as a 3d visualizer: http://www.citypixels.be
