Can I import Camera Raw settings?
COW Forums : Adobe Photoshop
Matteo Badin
on Aug 8, 2018 at 10:30:53 am
Hi everyone, Camera Raw automatically saves the settings in a .xmp file located in the folder where my RAW photos are. I was wondering if these settings can be imported in other RAW files (in order to save time while post-producing my photos) and how I could do it. Thanks!
Kalleheikki Kannisto
Re: Can I import Camera Raw settings?
on Aug 8, 2018 at 4:50:10 pm
I believe this article will answer your question quite thoroughly:
http://www.peachpit.com/articles/article.aspx?p=2111972&seqNum=18
In brief, you can save and load RAW settings in Photoshop. Using Bridge you can process multiple photos with the same settings on open. More details in article.
There is also the quick option to "use previous correction" in the Photoshop open RAW dialog if you know you want to apply the same correction to just a few files without saving the settings.
Senior Graphic Designer
Matteo Badin
on Aug 8, 2018 at 5:45:43 pm
Great! Thank you very much!
