Reposition objects in same vanishing point plane
COW Forums : Adobe Photoshop
Carlos Zapater
on Apr 25, 2018 at 10:18:33 am
Hi all.
I'm starting to use the vanishing point filter in Photoshop CS6 and I'm having a problem I can't solve. My goal is to place several texts and logos in the same perspective plane and for that I saw that the vanishing point filter could be the tool I needed.
I copy and paste all the texts and logos inside the pane with no problem. But then it is like there's no way to go. That ends there and I'm not able to move the objects without duplicating them which causes a mess. What I wanted to do is having them all in the pane and then relocate until I think they are in the definitive position but right now once you paste an object and move it into the pane it looks like that will be the final position.
Is that right or can you edit the position of the objects after you click 'OK'?
Thanks very much-
