Alpha Chanel JPG
COW Forums : Adobe Photoshop
Nathan Kendall
Alpha Chanel JPG
on Feb 28, 2018 at 10:13:41 pm
I have a design for t shirt.
I am assuming it should be in CMYK for print. However when I designed it I had the document set to RGB with a cmyk proof.
the save as panel says all the formats and below that is alpha Chanel. weather I have jpg or bitmap selected I can not select alpha Chanel. How can I save high res image with alpha Chanel?
Graham Tees
Re: Alpha Chanel JPG
on Mar 1, 2018 at 6:38:53 am
Jpg does not support alpha channels. If you want to save a transparency channel you need to save as a .psd or TIFF or .png.
Bouke Vahl
on Mar 1, 2018 at 9:05:34 am
Jpeg DOES support an alpha channel. Just lots of software does not allow for it.
After Effects can do this. (although not the tool for this job though.)
Bouke
http://www.videotoolshed.com
