Saving as a PDF - displays way too big
COW Forums : Adobe Photoshop
chris brett
on Jan 29, 2018 at 6:23:04 pm
Hi ----- have art worked elaborate A4 invoice in Photoshop
- all ok but I have a problem when exporting as a PDF to email to client
--- it displays way too big in adobe reader and the type looks dreadful ---- its as if adobe reader does not interpret the 'image size' settings properly from PS ( ? ! )
------------------ anyone know how how to export so that it actually display as an A4 sheet and is nice and sharp please?????
--------------------------------------------------- chris
Tom Van Damme
Re: Saving as a PDF - displays way too big
on Feb 1, 2018 at 8:41:43 am
Hi Chris,
is your resolution set high enough? Anything under 150dpi will look blocky (300dpi usually does the trick).
And what do you mean with "way too big in adobe reader" - is the page size off? You can check the actual page size under File>Properties…
Or does it just show a part of the page when you open the file.
I don't think there is an option in Photoshop to make PDF files display as "fit to window" by default.
Tom
chris brett
on Feb 1, 2018 at 5:59:43 pm
Hi Tom and Walter
-------- many thanks for your speedy replies - much appreciated
------------------- I can see this is almost certainly the answer .... will sort in a bit
------------------------------------------ all the best ------------------------------ chris ---
