How do i edit and then save a png sequence?
COW Forums : Adobe Photoshop
Richard Garabedain
on Aug 18, 2017 at 3:19:36 pm
What are my limits. I want to add filters and adjustment layers to a png sequence and then save it and import it into after effects as video. I have been searching but haveni found any good answers or tutorials. I even treid it myself but nothign happens.. it imports 1 frame and tells me thats the sequecne..but when i edit and save its only that one image.
Richard Garabedain
Re: How do i edit and then save a png sequence?
on Aug 18, 2017 at 4:09:09 pm
OKay..i did get it to render out video but myeffects are still pretty limited...anyway to expand or thats all i get
Ian Watkins
on Sep 25, 2017 at 10:13:20 pm
First off, have you tried going to File > Export > Layers to Files ?
It'll prompt you and ask you what kind of file you want and where to export it. Then when you go to import into After Effects, select all the files you wish to import and the click "import as sequence". I believe that'll get you what you're looking for.
Why not try doing all your adjustments and color corrections in After Effects instead? It's an easier workflow for me, personally.
Hope that helps
