photoshop files and premiere pro
COW Forums : Adobe Photoshop
kerry baldry
on Aug 4, 2017 at 12:57:48 pm
photoshop file black when in premiere pro.
When I go into premiere pro cc
into New: New photoshop file
a file with the same settings (whatever settings i have chosen) is automatically
made in photoshop.
However the although the two are linked the image in premiere pro is black.
Steve Bentley
Re: photoshop files and premiere pro
on Aug 4, 2017 at 4:32:41 pm
Does it have an alpha channel? ( in this case it might be black and therefor not letting the RGB pass through and looking black
kerry baldry
on Aug 4, 2017 at 6:45:00 pm
Hi, yes just checked. it has an alpha channel
Steve Bentley
on Aug 5, 2017 at 1:00:58 pm
So you can tell premiere to ignore the alpha and that should do it
kerry baldry
on Aug 5, 2017 at 1:39:37 pm
thanks.. tried that. still doesnt work.
Steve Bentley
on Aug 5, 2017 at 6:19:39 pm
Sorry to here that. Is it perhaps a layered file and premiere is only grabbing the base layer and that is either black or has nothing in it?
Is it in a color space that premiere can't do or isn't set up for (16 or 32 bit)?
Is it a tiff perhaps that has a mac encoding or vs a PC (same goes for Targas).
Does it have a compression on it that premeire or your computer cant't do?
kerry baldry
on Aug 6, 2017 at 8:01:38 am
thanks, I will try all this
Boris Redgard
on Aug 17, 2017 at 3:01:50 pm
Hello! Tell me, what helped you? How did you get rid of the problem with this photo file? It seems that I have the same problem.
