Adding brushes within a object boundary
COW Forums : Adobe Photoshop
katie wes
on Jul 13, 2017 at 5:36:47 pm
I'm sure I've done this before but I'm having a mental break and can't remember how you do it. I've drawn an object within illustrator and exported it into photoshop to add detailing. But I only want the brush strokes visible within the object - with no overlap into the background like it is in the attached image.
How do I do it? Do I need to mask the object and then put the brush strokes?
Jeff Hinkle
Re: Adding brushes within a object boundary
on Jul 13, 2017 at 8:55:45 pm
In your Layers palette, click the Lock Transparency switch along the top (looks like a little square checkerboard), or hit your "/" key (next to Right Shift, same key as "?"). Either way, transparency will be protected and your strokes will only affect areas with opaque or semi-opaque pixels.
It is easier to destroy than to create.
More fun, too.
katie wes
on Jul 14, 2017 at 8:41:56 am
Amazing, thank you :D
