naming of merged layers
COW Forums : Adobe Photoshop
ellen osborne
on Feb 17, 2017 at 12:00:43 am
Hi All,
When I merge two layers, the new single layer always takes on the name of the top layer of the two that I merged. Is there any way to get the new single layer to take on the name of the bottom layer of the two merged layers?
Thanks for the help.
Ellen Osborne
MacPro (Late 2013) 32 GB Ram
Katarzyna Kuzawska
Re: naming of merged layers
on Feb 23, 2017 at 11:31:41 am
It happens when you select 2 layers and then use option Merge Layers, it's useful when merging more than 2 layers.
If you aim to merge TWO layers, you can use option Merge Down - then the new layer will be named as the bottom one ;)
