Free transform tool not working properly in Photoshop CS6
COW Forums : Adobe Photoshop
Lubomir Missov
on Jan 6, 2017 at 11:11:50 pm
Hello,
Wanting to transform (scale up) a picture. I use Ctrl+T (on PC) and handles appear. When I drag any of the handles they move out of the picture but the picture "stays" visible only in its "initial box". It does transform but only in its original window - the transformation does not extend out of the original size of the picture. It seems like I am doing a transform and cropping at the same time.
Along with English I have Cyrillic and sometimes it gets enabled if I hit the "wrong" key. Before I realize it I may have hit Ctrl+ something in Cyrillic and that may have caused this mode. I don't know what command it has been.
Thank you very much for any help.
Happy New Year!
Luby
Luby
Selen Jain
Re: Free transform tool not working properly in Photoshop CS6
on Jan 12, 2017 at 10:22:30 am
Sorry cant be able to give you the exact solution but you can see this post for some idea http://guides.lib.umich.edu/c.php?g=283204&p=1886609
https://www.clippingpathspecialist.com
Gavreel New
on Oct 20, 2017 at 7:54:26 am
When you create a new layer, change the transparent background to white. Problem solved.
