Color Settings... vs Convert to Profile...
COW Forums : Adobe Photoshop
Jerry Smith
on Oct 25, 2016 at 5:37:13 pm
I have a document that I made. Under color settings, it says North American General Purpose 2, and the Working Spaces are first sRGB IEC... But when I go to Convert to Profile, it says Profile: Apple RGB.
So, I'm confused. What is the working space of the document? I'm more familiar with AE's working spaces.
Jonathan Ziegler
Re: Color Settings... vs Convert to Profile...
on Oct 26, 2016 at 1:04:07 pm
The working space is just that: a space to work on the image without changing the existing color profile (if any). It looks like you image was already set to Apple RGB and you were using sRGB to do your editing (working space). Using Convert will change the image from Apple RGB to whatever space you like. If your images are usually Apple RGB, you can change your working space to the same.
I do a lot of photo work so I use Adobe RGB for my working space and my default color space. I also like the way it handles my colors. If I'm working for the web, I use sRGB because it more Slidell resembles the final colors and most browsers ignore color space anyway.
Found this article: http://www.peachpit.com/articles/article.aspx?p=1315593&seqNum=3
Hope this helps.
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
William Hopkins
on Oct 29, 2016 at 11:20:42 am
Thanks for help, I wanted to set it.
