Photoshop CS6
COW Forums : Adobe Photoshop
Kelly Whitaker
Photoshop CS6
on Sep 13, 2016 at 5:36:09 pm
Hello everyone. I need help with Photoshop CS6.
When I try to open Photoshop psd file I receive this error:
Could not load actions because an unexpected end-of-file was encountered and the program would not open.
how to fix a corrupt psd file ?
Thanks.
Kelly Whitaker
Re: Photoshop CS6
on Sep 14, 2016 at 4:45:41 pm
Who knows how to help me?
Kalleheikki Kannisto
Re: Photoshop CS6
on Sep 15, 2016 at 7:29:23 am
There are various programs that claim to fix corrupted Photoshop files, such as this:
http://www.psd.repair/psd
Almost all of the problems I have with Photoshop files comes from transfering them by email, in which case I simply ask the sender to resend it. So if that is the case here, you know what to do.
If the file was corrupted due to a computer crash while saving the file, the chances are there's little to be done. In a couple of cases I've managed to restore a partial file, but more often than not I've ended up having to rebuild it. Although this hasn't happened to me in two decades: I learned early enough to separately save (to a new file with a revision number) any major versions of the file as I go.
Senior Graphic Designer
Jannatul Shumi
Re: Photoshop CS6
on Sep 20, 2016 at 10:42:13 am
STEP 1: Navigate to your home folder -> User Library
STEP 2: From there navigate to Preferences folder.
STEP 3: Search for Adobe Photoshop settings folder -> Delete the folder completely.
STEP 4: Restart your Mac once and then start the photoshop application again which should work now without any errors or problem.
http://www.clippingpathspecialist.com
Jack Chase
Re: Photoshop CS6
on Sep 22, 2016 at 8:30:48 pm
Kelly,
If this is happening when you start Photoshop. Stop Photoshop. If it useless maybe youe psd file is corrupted. In this case try Photoshop Fix Toolbox https://www.fixtoolbox.com/photoshopfix.html
This application can restore the data from all versions of Adobe Photoshop.
Best Regards,
Jack Chase
Douglas Alvarez
Re: Photoshop CS6
on Sep 28, 2016 at 5:41:27 pm
How many solutions, one of these might help me.
