Convert multiple path points at once
COW Forums : Adobe Photoshop
Matt Hopkins
on Aug 16, 2016 at 7:50:25 pm
Is there a way to convert a bunch of selected points at one time?
I'm working with a distressed font, which I am turning into a Work Path. I need to convert all the points from smooth to corner. I'm hoping there is a quick way that doesn't require me to click on each point.
Matt
Kalle Kannisto
Re: Convert multiple path points at once
on Aug 16, 2016 at 8:51:21 pm
Online manual: "To convert one or more smooth points to corner points, select the points and then click the Convert Selected Anchor Points To Corner button in the Control panel."
https://helpx.adobe.com/illustrator/using/editing-paths.html
Edit: Oops, sorry, that's Illustrator, but if you have Illustrator, you could copy them to Illustrator for conversion and back to PS.
Kalleheikki Kannisto
Senior Graphic Designer
Matt Hopkins
on Aug 16, 2016 at 9:21:50 pm
Thanks Kalle. I'm a pretty light Illustrator user, but I'm kicking myself in the pants for not checking to see if I could do it there. Good call.
Matt
