Tutorial for open wooden window frame
COW Forums : Adobe Photoshop
Dave du Plessis
on Aug 16, 2016 at 6:35:25 pm
Good day .... in my search for a tutorial that lasts for weeks, I came across this site and joined because I know I will find what I was looking for. I would very much like a tutorial to build an open wooden window frame with Photoshop. I use PS CC2015 and the window must be actual window size to make a fake window so a picture can be placed behind it. I'd like it to be in multi (at least two) panes (windows opening to left and right). Thanks in advance:-)
Dave du Plessis
Re: Tutorial for open wooden window frame
on Aug 16, 2016 at 8:26:56 pm
In follow-up to my question, here is a perfect example of what I would like to build in PSD.
In fact, I would like to be able to build the same frame in Photoshop.
https://www.toperfect.com/View-of-Paradise-magic-3D.html
Kalle Kannisto
on Aug 16, 2016 at 9:02:12 pm
You could use Filter Forge to create wooden frame pieces to the size you want and combine them in Photoshop in flat view, then pespective distort the two sides to make them look like the windows are open.
Here's a nice wooden frame filter: https://www.filterforge.com/filters/11740-v5.html
Filter Forge is commercial, but there's a 30-day free trial with up to 3000x3000 pixel rendering capability.
Kalleheikki Kannisto
Senior Graphic Designer
Dave du Plessis
on Aug 16, 2016 at 9:08:27 pm
Wish I joined here longer ago! Thank you for the prompt reply, Kalle. :-)
