Collaboration Project Sharing
COW Forums : Adobe Photoshop
Joseph Moore
on Aug 5, 2016 at 2:47:47 am
I'm working with some friends/freelancers on different projects. We often need to transfer files to one another in order to review changes, but we want a high speed file transfer because any delays can make simple decisions painstakingly slow. Anybody know of any hot folder type setups that will automate file transfers and allows us to monitor file transfers? This would let us share quickly without having to continually message each other or be afraid of deleting something that hasn't been transferred successfully. Feeling a bit desperate, maybe it's the the summer heat getting to me, but any and all ideas are appreciated!
Kalle Kannisto
Re: Collaboration Project Sharing
on Aug 5, 2016 at 5:16:43 pm
Apparently there is a whole version control system in Adobe Bridge with Adobe Experience Manager (which I've never used). It seems almost impossible to find an explanation of how it is set up and works, but looks to be simple to use once set up. The white paper here: http://www.adobe.com/content/dam/Adobe/en/solutions/web-experience-manageme...
Kalleheikki Kannisto
Senior Graphic Designer
Shiu Ka Heng
on Aug 9, 2016 at 2:05:30 am
Make a VPN server on a computer and ask your friends to join, then use this: http://www.d-lan.net/
milos veljkovic
on Aug 19, 2016 at 5:32:44 am
Even though you guys are freelancers, it sounds like you need a professional level file transfer system if you are working on a lot of time sensitive stuff. I'd recommend you look into some managed file transfer or express file transfer software solutions. Many of these are paid software, but if I come across some free or cheap options I'll paste in the links.
milos veljkovic
on Sep 21, 2016 at 5:43:01 am
Here's a short list I came across that might be of help (ordered from cheapest to most expensive):
FTP | Filezilla
WebRTC | https://webrtc.org/
rysync | https://rsync.samba.org/
Innorix | Innorix Large file transfer
