Photoshop: Showing description
COW Forums : Adobe Photoshop
Ben Albright
on Dec 6, 2014 at 10:34:48 am
In Photoshop CS5, I have it set to print at 25% size with the file description under it. The problem is I don't want to print. I want to just see it in front of me, and take a screenshot. I don't really know how else to explain it, but I know if I save it as a pdf, there's a way I can see the description, but I don't know how to get it to show up.
Todd Perchert
Re: Photoshop: Showing description
on Dec 8, 2014 at 3:31:50 pm
When you select to Print, a dialog box should come up. Inside that box should be Print Settings. If you go there you should be able to select to print (save) to a PDF.
Good Luck!
TC
Ben Albright
on Dec 9, 2014 at 1:38:57 pm
Todd, I don't see that option anywhere. This is what I get when I click "print settings". "PDF" isn't listed anywhere under these tabs.
Todd Perchert
on Dec 9, 2014 at 5:22:58 pm
Ah! Windows. Do you have Adobe Acrobat installed? If so, when you go to print you should have the option to select print devices - don't select your printer, select Adobe PDF. If you don't have Acrobat, get it, install it.
Good Luck!
TC
Ben Albright
on Dec 9, 2014 at 11:53:42 pm
Alright, thanks. I'm not paying $100 dollars just to have that feature, so I guess I'll have to do it manually.
Todd Perchert
on Dec 11, 2014 at 5:21:49 pm
I believe you only need the free Acrobat Reader, but I could be wrong.
Jannatul Shumi
on Jan 31, 2015 at 9:28:31 am
Can you upload a screen shot of your setting, what you actually want?
