adding layer mask problem, (CS5 mac)
COW Forums : Adobe Photoshop
sonia megerdichian
on Jul 30, 2012 at 5:59:45 am
Hi, I'm working with CS5 mac 10.5.8, working with raw files .CR2
I'm trying to add a adjustment layer to an image with layer mask as follows: add adjustment layer, option click layer mask, select brush tool (100% Opacity) make sure the white for the mask is selected and paint with my brush, but nothing happens.
I tried the same thing but instead of the adjustment layer I duplicated my background then option clicked the layer mask, and it works.
the only difference I noticed between the two is that when adding the layer mask to the adjustment layer, the mask that appears in the little icon is grey. however when adding the layer mask to the actual duplicated background, the icon is black (which is how I think it should be)
what am i doing wrong? please help! thank you!
Darby Edelen
Re: adding layer mask problem, (CS5 mac)
on Jul 31, 2012 at 2:23:11 am
Adjustment layers usually come with layer masks by default, so you shouldn't need to add one, just work with the one that's already there. It sounds like you may be adding a Vector Mask to the adjustment layer.
Darby Edelen
sonia megerdichian
on Jul 31, 2012 at 6:28:31 am
thank Darby! I kept thinking I needed to add a layer mask... that was it. It works now, I just had to invert the adjustment layer. Thanks for taking the time to answer!
Sonia
