Not allowed to do anything in CS5 - cursor is circle with line through it.
COW Forums : Adobe Photoshop
tad newberry
on Oct 12, 2011 at 6:17:25 pm
I use Photoshop only a couple times a month - quite a novice, but last time it worked fine. Today i open it and my cursor is the circle with a line through it...can't do anything. Any ideas?
thanks for helping out a bonehead!
__________________________
FCS3
2.66 GHz Quad-Core Mac Pro
6GB RAM
NVIDIA GeForce GT 120
...and a few TeraBytes o' storage
(then it's on to PetaBytes, ExaBytes and MosquitoBytes!)
Simon Harris
Re: Not allowed to do anything in CS5 - cursor is circle with line through it.
on Oct 13, 2011 at 1:38:49 pm
What is on the layer you are trying to edit?
This usually happens if you are trying to edit a type layer or smart object before rasterizing the layer.
if it is type or a smart object, right mouse click (ctrl+click for mac) on the layer name in the layer pallette and chose rasterize Type/Layer.
Hope this helps :D
Sye
tad newberry
on Oct 13, 2011 at 6:52:57 pm
Thanks, but it was any and every file i opened...even new ones, so i reinstalled the software and all is well. Thanks though.
FCS3
6GB RAM
Scott Roberts
on Jan 2, 2012 at 4:20:30 am
Apps can get wonky if you're not repairing permissions on a regular basis. You can also leave your computer on all night to automatically run scripts that will repair permissions. To run them yourself, use Disk Utility: http://kb.iu.edu/data/aoxn.html
LittleBlackBird.net
My Blog
