Movng Transform Handles
COW Forums : Adobe Photoshop
John Phillips
on Sep 19, 2011 at 3:03:41 pm
Hi all,
I have a project where I'm trying to exactly align up the corners of four very large maps so that I can build a single map image out of them. Each one is about 40" x 30" in size. Since they weren't scanned exactly the same, I'm trying to transform skew the corners into the same position using one map as a reference. From there I can then be assured that they are all the same size and can proceed to build the single image out of them.
What I'm wondering is if there's a way when I'm zoomed into the corner of the maps if I can move the transform handles so I can use them while zoomed in. Right now when I zoom in the handles go outside the working area of the window and I cannot access them.
Any suggestions?
ben g unguren
Re: Movng Transform Handles
on Sep 22, 2011 at 6:47:38 pm
You can use numeric transformations at the top of your PS window....
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.com
John Phillips
on Sep 22, 2011 at 7:49:24 pm
Hi there,
I tried doing the transforms numerically but unless I can grab one of the four corner handles, the numeric x/y value moves the entire layer. Is there a way to specify the numeric value controls a specific corner handle?
John
ben g unguren
on Sep 23, 2011 at 1:25:23 pm
I don't think you are able to do individual corners numerically (though I agree it would be useful sometimes!)
Ben Unguren
