COW Forums : Adobe Photoshop
Dan Newton
on Apr 12, 2011 at 1:52:30 pm
I am in need of some urgent help:
I would like to know the following:
I have received a psd file with text in one layer and on another layer a logo the size is 1280 x 720
I would like to know how I can re-size the psd file to 720 x 576 without making the text or logo looking squeezed
could you please provide me with a tutorial
Hope to hear from you soon.
Christina Rodriguez
Re: resizing
on Apr 15, 2011 at 8:08:08 pm
Method 1:
This is for video right? (i'm guessing because of the size) Make a new file, using the video preset that matches your settings (I think in your case it would be PAL D1/DV, 720x576 (with guides)). Then drag your logo into your new psd file and scale it down until it fits, using shift to maintain ratio. Then Flatten. save as psd. (if it has a transparency, you can make an alpha channel and have a completely flat psd, much smaller size) or just leave the transparent logo on it's own, delete any empty layers.
Method 2: Crop it...
go the the crop tool... there should be an option to enter your exact pixel width and height... then select the area you want to crop, hit enter and viola. it will scaled down everything... But I think the 1st method is best because of the pixel aspect ratio.
Make sure you save-as so you don't save over your original.
© 2018 All Rights Reserved
