Preserving Alpha Channel for FCP?
COW Forums : Adobe Photoshop
Eric Lochstampfor
on Jan 12, 2011 at 8:05:16 pm
I'm trying to use a logo, made by our graphic artist in Final Cut, only when I go to it has a white background. When I view it in Photoshop I can see through to the checkered background, so I am assuming the alpha channel is present.
I've tried re-saving it and that causes the background to turn black.
The PSD is a school logo with only has one layer.
Any idea what I need to do to be able to use the logo and still get the alpha channel, or where the problem might lay?
Thanks in advance!
Christina Rodriguez
Re: Preserving Alpha Channel for FCP?
on Jan 13, 2011 at 1:39:17 am
Make sure the logo is in RGB mode (in Photoshop)
Try, in FCP. with the image selected in your timeline, go to Modify>Alpha TYpe and see if it's set to none/ignore. If so, change that setting.
If that doesn't work, let us know.
C.R.
Eric Lochstampfor
on Jan 13, 2011 at 2:47:23 pm
Yup!
RGB Mode did the trick.
Christina Outlaw
on Mar 8, 2011 at 12:41:20 am
For future reference RGB mode is effective because CMYK is not detectable by FCP.
Hope that helps.
