re-set workspace to default
COW Forums : Adobe Photoshop
Chris Gallaway
on Dec 7, 2010 at 10:40:25 pm
Hi folks,
I'm a novice in photoshop, and while working with the program recently I hit a keyboard command which changed my workspace in an undesirable way. Formerly, when I would open documents in Photoshop they would load into individual windows that would be layered across the workspace. I could select between the windows, drag to move them, etc. Since hitting that unknown command, my workspace has been filled by a single document window. Now, when I load many images I can only see the top one--it spans the workspace and has no border to drag or manipulate the window. I've looked through view options and have found now way to restore the former settings. I'd really appreciate any help that ya'll can offer towards getting me back to the old setup.
Many thanks, ya'll!
Chris
Christina Rodriguez
Re: re-set workspace to default
on Dec 11, 2010 at 5:07:59 pm
DId you try: WINDOW>Workspace>Reset Palette locations?
Or did you press "F"
I'm on a Mac and have an older version of photoshop... So this may not work for you.
C.R.
Chris Gallaway
awesome, thanks!
on Dec 11, 2010 at 11:55:55 pm
hitting "f" did the trick. I knew I'd tapped some shortcut on the keyboard--thanks for helping me find my way out.
-Chris
