Anchor points on circle
COW Forums : Adobe Photoshop
Kurt Richardson
on Nov 23, 2010 at 3:04:52 am
Hi everyone, not sure if I'm missing something obvious here, but how do I put anchor points onto a circle once I have drawn it with the elliptical marquee? Should the circle be selected or de-selected? The "add anchor point" pen tool only allows me to outline a box but otherwise does nothing. Any help would be greatly appreciated!
David Cabestany
Re: Anchor points on circle
on Dec 13, 2010 at 8:36:32 am
you can only add anchor points to a path, when you use the elliptical marquee you're actually doing nothing, just selecting a portion of your image, that selection can be modified by going to select>transform selection, but you can't add anchors to it, those belong to bezier curves only.
