change layer name to content of text
COW Forums : Adobe Photoshop
Jason Brown
on Feb 26, 2010 at 4:55:22 pm
I created a new text layer...the name of that layer was what was typed in the layer.
I accidentally clicked and renamed the layer. Now I can't get it back to update to what the text says...I can manually change it, but how do you make it change with the text once you've changed it?
-Jason
John Mensinger
Re: change layer name to content of text
on Feb 26, 2010 at 7:19:29 pm
I'm reasonably certain that the initial text input=layer name is the extent of the automated feature. After that, layer renaming is manual only.
John M:
All of the vim with none of that annoying vigor.
Jason Brown
on Feb 26, 2010 at 7:42:53 pm
Mine (CS4) will continue to update the text based on the contents (until you manually change the name) - once you do that, I can't get it back to auto updating.
Theo van Laar
on Mar 10, 2010 at 7:38:09 pm
'Mine (CS4) will continue to update the text based on the contents (until you manually change the name) - once you do that, I can't get it back to auto updating.'
My CS4 is behaving exactly the same.
Theo
