Resetting View to Single Screen
COW Forums : Adobe Photoshop
John LeBlanc
on Sep 23, 2009 at 3:13:54 am
Using Photoshop 6, I've moved from a 2 monitor setup to a single monitor setup, where the window showing effect controls was displaying on the second monitor and everything else in the first monitor. (I no longer have a dual monitor)
Now, on a single monitor, when I click effects under layers with an open project, Photoshop is still thinking there is a second monitor, and I cannot see the effects window that pops up, so I have no control over Photoshop once I click on effects. The only way I can get back control and quit the window (that I cannot see) is to shut down Photoshop through force quit.
How do I reset Photoshop to make it utilize only one screen so that all of the windows within Photoshop will open back up on the single screen?
Art Doerge
Re: Resetting View to Single Screen
on Sep 23, 2009 at 7:21:38 am
Hi John,
Well, I've never used two monitors so I can't be sure but.... I really don't think that would be something you would set up in Photoshop. I'm on a Mac and I think to use two monitors I would go to "Displays" in Preferences and tell it to "Detect Displays".
On a PC running Windows, probably right click to Properties > Display Properties > Setting?
If you still have the problem, you might try re-creating Photoshop's preferences but I don't think that should be necessary. Anyway, to re-create the preference files for Photoshop, start the application while holding down Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS X). Then, click Yes to the message, "Delete the Adobe Photoshop Settings file?"
Hope this helps.
Richard Harrington
on Oct 5, 2009 at 12:21:15 am
Window > Workspace should do it
Richard M. Harrington, PMP
Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
© 2018 All Rights Reserved
