How do you do this?
COW Forums : Adobe Photoshop
craig c smith
How do you do this?
on Feb 9, 2009 at 6:18:44 pm
I hope I explain this. I am looking to take multiples jpegs (100) and put it together on one sheet. I am not sure on how to do it. I want to size each Jpeg of equal size to fit. I guess I have to set up some type of grid. I am not sure how to do that. and if there is an automated way of placing the jpegs. Thanks in advance.
Jeff Kelley
Re: How do you do this?
on Feb 13, 2009 at 5:41:12 pm
Are you using Photoshop or Photoshop Elements? Check to see if you have Contact Sheet under File/Automate, that should do all you want.
http://www.willinois.com
craig c smith
on Feb 13, 2009 at 7:54:20 pm
No I am using Photoshop CS4. I did it the hard way. I made each jpeg 2" by 2" 72 DPI and then place each one indiviually on a large background sheet. It took a couple of hours. I was wondering how to automate something like this. Thanks for you response.
Jeff Kelley
on Feb 13, 2009 at 9:37:46 pm
If you have SC4, you can make contact sheets. That is the way to automate it. I use it everyday.
