Help to render out video CS3 extended
COW Forums : Adobe Photoshop
Catherine Peterson
on Dec 27, 2008 at 2:13:54 am
Hello,
I have tried to export video out of CS3 extended no matter what I've tried a get the same message "Could not complete the render video command because of a program error"
I can import .avi and quick time files just fine but it won't export. Whether I choose .avi file .flv or quicktime. (using only a 25mb sized file) I still get an instantaneous pop up error.
Please I really could use your help as I have not found any info thru google searchs. I have no problems rendering from After effects CS3 or Premiere Pro CS3, just photoshop CS3. I installed PH as part of the Production Premium creative suit.
windows XP pro SP3
Photoshop CS3 extended
4 gigs ram, ATI 2900 pro video card Asus PB5 deluxe CPU E8400
Richard Harrington
Re: Help to render out video CS3 extended
on Dec 31, 2008 at 5:49:31 am
Run Updates.... if not work.. reinstall...
you may have upgraded OS after PS install and are missing some components.
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
Catherine Peterson
on Dec 31, 2008 at 6:50:09 pm
Thank you so much for your reply. I have not updated my OS since I installed CS3. I will try reinstalling though.
tammie inkley
on May 8, 2009 at 1:34:22 am
I also have tried to export video out of CS3 extended and no matter what I've tried I get a similar message "Could not complete the render video command because of the file could not be found" . Also
I can import .avi and quick time files just fine but it won't export or render.
