How do I create an irregular shaped marqee?
COW Forums : Adobe Photoshop
matt steel
on Dec 19, 2008 at 11:11:58 am
Hi guys
I want to create an irregularly shaped vignette to export from CS3 and import into Avid.
All tutorials on vignettes begin with creating a marquee shape and then inverting, filling with black and feathering.
I don't want a regular rectangle or ellipse though.
How do I draw an irregular shape to make a vignette?
Many thanks
Matt
Emily Carmichael
Re: How do I create an irregular shaped marqee?
on Dec 20, 2008 at 3:40:13 am
You can use literally any selection tool to define the shape of your vignette.
The lasso tool allows you to select freehand and the polygonal lasso lets you make polygons. You can also use any color-selective method to select an area that's the same shape as something else in the frame... you get the idea.
Since you plan to feather the selection, drawing it freehand with the lasso tool is probably fine, but if you want more precise curves you should use the pen tool and then convert your path to a selection.
