Printed Photo different size to photo in Photoshop
COW Forums : Adobe Photoshop
John Orr
on Nov 10, 2008 at 5:05:26 am
I am new to Photoshop CS3 and was wondering if someone can help me with printing the same size photo that is in the photoshop screen.
Thank you in advance for any help you can give me.............John
Jeff Kelley
Re: Printed Photo different size to photo in Photoshop
on Nov 10, 2008 at 5:19:55 pm
What do you mean, the same size as the photoshop screen? Do you mean as it appears on the monitor? Go to Image/Image Size and that will tell you the size it will print.
http://www.willinois.com
John Orr
on Nov 10, 2008 at 5:30:11 pm
Thanks for your reply. Ok, I guess what I mean is when I print the Photo it has cropped some of the side and bottom off, so I dont get the whole image that I see in photoshop..............John
Jeff Kelley
on Nov 10, 2008 at 7:52:34 pm
When you print, click scale to media in the print window
John Orr
on Nov 10, 2008 at 8:38:29 pm
Thanks again, I already have the " Scale to fit Media " selected..........................John
Jeff Kelley
on Nov 10, 2008 at 9:41:45 pm
The only other thing you can do is see how much that feature is scaling it at manually scale it a little more. If I should guess, the right PPD is not selected because the PPD should know where the margins of you printer is.
John Orr
on Nov 11, 2008 at 4:37:23 pm
Thanks for all your help Jeff, that helped, still a bit out, but I can live with that. Again thank you................John
